Factory Five MK4 – One of a Kind! Aluminum Body - Aluminum Tub
*Drastic price reduction ...moving overseas ...
Looking to see if there is any interest as I am working overseas for the next few years due to a large promotion and the project Has stalled.
I have welded a complete Aluminum Tub into the chassis. There are no rivets at all. The rest of the panels are heavy aluminum and nut certed. When the welding was done I powder coated the entire chassis. This is a complete kit with every upgrade available. NO used parts have been used.
I have the original fiberglass body BUT I have also created an Aluminum Body, The body is almost complete. The hood and the trunk are shaped but will need finishing and support structures created.* I was going to use the fiberglas doors but it someone wants to make Aluminum doors they would not be difficult to make. This is truly a one of a kind build and not for the faint of heart. It will be Beautiful when done.
I do have everything to finish the build but the time.
Engine Ford 331 built with Aluminum Heads “Canton” and dual carb setup. Completely Detailed
Performance Fuel system everything is Aeroquip with a fuel cell.
TKO 500 new and power coated
IRS everything Powder Coated
Brakes are Wilwood
Have original fiberglass body as well!!!!
Let me know if you have any other questions. I am in FT. Lauderdale FL - 27k have a ton more into it…Needs a good home and a person that can finish it. It’s absolutely perfect!
757-472-6007
[email protected]
Brakes are Wilwood
757-472-6007
[email protected]
