1 - 17 of 17 Posts
I have had the extra port on my water pump blocked off for the past 3 yrsa and yesterday the rubber cap I'm using sprung a leak. I don't like the idea of using such a weak cap.
What is everyone else using?
Originally posted by ND:
We crushed the tube and pulled it out of the water pump. Replaced it with a freeze plug.
any pics of that?
I pulled the plug out and tapped it and put a screw in plug.
Troy
Why can't you just put a freeze plug in the tube without removing it?
Cone Killer
like 7Tvette I pulled the tube out and tapped the hole (NPT) and inserted a plug.
picture added
[ April 25, 2007, 09:36 AM: Message edited by: P_Matt ]
I like the idea of tapping it. After 3000 miles I'm on my third rubber cap. :(
Master Blaster
can you run a hose from the extra plug on the water pump (return line) to the driver side rear of intake and use it to help reduce hot spots in the engine? just a thought!
I ended up leaving the tube in place and using a deep well freeze plug into the top of the tube. I used JB weld to help seal and keep the freeze plug in place. My plan is to use a rubber plug in addition just as a backup. I've haven't added the rubber plug yet and I've been go-karting around and haven't had a single leak yet.
- Colby
Discussion Starter · #12 ·
OK Thanks guys!
What is the small hose for, I think its called the bypass? Can you remove both?
Whay size are you guys tapping it to, and how tough is it to pull out the tube?
Trev I'm thinking with both ports closed,when t stat is used. Engine would have no flow of coolant thru the block. Thinking hot spots,or at least a big strain on the water pump from dead heading by not having any place to relieve the pressure water pump builds. Might cause cavitation in the pump?
One port was used for heater core that can be eliminated. Second port,the one that ties into the t stat housing is a by pass to circulate some amount of water thru block when t stat is closed. Probally helps t stat open at the correct temp also,but not sure.
If not useing a t stat probally would be ok to block off.
Cone Killer
Ed,
1/2 NPT. The tube just pulls right out.
Do not remove or block off the bypass port. It's needed to insure proper water circulation and to prevent hotspots during warm up.
1 - 17 of 17 Posts
