1 - 20 of 22 Posts
East Texas Muscle Cars Kit car build: This will take a while as i am building this myself and not really in the shop so this is a 9pm to 12AM project but in 4 months i has got quite a bit done!
Car will be a LS powered car
Sence i was 11 years old and saw the first AC cobra and actually knew what it was i have wanted one. Well i finally had the chance to build me one. I had to sell my 1100+ HP 2010 camaro I built But i got it.
Kit was delivered about 4 months ago:
Super excited about right now!!!! Got the car out then had to unload all the boxes
First things first, found the instructions:bang::bang::bang:
i bought a basic kit with all FFR a arms and wilwood brakes, and a moser 8.8.
the car didnt come with the Brakes or the Moser 8.8 so more boxes soon to come! :D
First off the car comes with the body set on the frame and the alum panels just set in place. You have to take the whole car apart, and label all the panels.
Then the fun begins. I started a little out of order but o well. here is the front end and brakes on.
rear end came in about 3 weeks later so in it went!
I will have to apologize now for he crappy pictures :-( they are all from my I phone
now to start on the ALUM. starting with the front:
and moving to the REAR
man that last pictures turned out really bad :-(
anyways at that point i have the gas tank installed already, all the alum is in and sealed. now that was the easy part now to start the brake lines,pedal box,dash, eng, trans......
Brake MC. o what fun, i still dont have them adjusted right may have to rear the instructions for these..LOL..
now it is getting time to move it down to the main shop so i can use the welder and get to going on the motor
so far no real complaints that i have found except the rear brakes i had to have machined to fit the 8.8
MOTOR TIME NOW
for the motor i went with a block i had sitting around the shop. a old ls3 crank. some Eagle rods and wiesco pistons. to top it off some PRC 317 2.5 heads with a ls2 intake.
Went with a fresh t56 and a ACT twin disk clutch
for the mounts i had to cut the ford ones off and make my own mounts. I got some HSC rubber mounts and use the FFR trans mount in the rear with a F body rubber mount. The mounts in the picture are just when i was mocking it up. They are now boxed all in.
THE CUT OFF MOUNT AND WELDED BACK ON
now for the fun stuff. Mocking up the Turbo kit, and putting the March front drive kit on the car
there isnt alot of room in the front of the car so i decided to go with a air to water setup :
if you look down you will see the two innercoolers
NOW TO THE DASH
Ill go take some nice pictures of the car today!!
here is how she sits today
now the body is another story. Me and our painter are not to happy with there( 40hrs and ready) body. after taking off the seams they leave you there is alot of voids in the fiberglass under the gel coat which is a big NONO. i am a little worried about the rest of the body and heat and those air bubbles we dont find coming back to haunt us down the road. there is a TON of high and low spots also. this car we want 100% perfect so there will be were guessing 80-100hrs of body work and all to get it right and painted.
o here is a sneak peak at what it will look like. it will be a black but it will have pearl in it, and some red peal stripes, ditch the big snorkel and the pass side roll bar. but there is my wheels photoshop on it also.
Looks like its going to be a very cool build.
Motor looks fantastic.
Keep the pictures and updates coming! :001_tongue:
Discussion Starter · #16 ·
Got the sound/heat mat down and laid in the carpet and got the shifter and my lil custom AC box made and installed
I have since sat the body back on the car to test fit a few things, and get the doors/hood/and trunk ready. Honestly this car hant been a nig PITA just finding time to do all the work is what has taken so long. i only h ve after work and weekends to work on it and its just me so im pretty happy with how far i have gotten
Also have installed and taken off all the lights, and everything that mounts to the body on teh outside to make all the holes needed for mounting and such,
1 - 20 of 22 Posts
