What's the best engine temp to be running at.
Mine fluctuates between 175 & 195 but today in heavy traffic she was going up and up.
Most carb guys shoot for around 180 degrees. Don't panic unless it starts staying above 210 all of the time.
It was up near 210. Engine was also strting to slow while it was at idle. Of course I'm thinking 'Oh-Crap' cool looking car will soon over heat. The light changed I moved and temp started to lower back to normal. I guess it's because I have gauges that actually seem to work so when I see the temp gauge at 195 and then it goes down before my eys to 175 I'm surprised. I always figure the thermostat must be opening and closing...Just Like it's Supposed to. I do wonder what is 'The BEST' thermostat to go with.
I have a 190 thermostat that was required when I had stacks on my car. The engine temp varies between 200 and 210. When the fan is on it is consistently 200 even on the hottest days. I figure I should change to the 160 so it will run 175 to 180 with the fan on hot days now that I have a carb.
Did you install under-drive pulleys on the water pump? I have them and I run in the 205 region all the time, and so far it hasn't been a problem but I am looking for solutions to run cooler (switching to an aluminum radiator and possible and oil cooler even though I have a 5.0L).
tim
With carb your ok with a 180* t stat. The secret is haveing a good fan controler that adjustable as to where it turns on and off. I try not to let the temp get lowwer then the stats opening temp and make the fan shut off at 180*. My fan is on at 195*,off at 180*,useing a 180* t stat.
When at idle along with the longer then normal distance the radiator is from the water pump. Not unusuall to see a slight temp spike as soon as you pull away form a long red light and water starts to circulate faster. Should recover very quickly thu. If sitting in traffic,I manually turn on fan to keep the temp spike to a minimum when car pulls away. Normal stop and go fan stays on auto.
