I have the FFR 2282, everything is stock from the 91 Mustang. The problem is that when I acelerate at normal RPM's, and I want to shift to second or third gear, the engine stay at relative high RPM's. I check the acelerator cable for binds, but it return to the original position immediately.
I check it at idle and it is the same problem.
The engine response very good, but when remove the aceleration, the engine go back to the normal RPM's, but it take about 2 to 3 seconds to go back to normal.
Any help will be apreciated.
Bernardo Aillon
Bernardo Aillon
