· Senior Charter Member
Hi guys, I have a question. What is a longblock and what is a shortblock? I have heard those terms used on many different posts and I have no idea what they are or what the difference is.
Thanks guys.
· FFCobra Fanatic
Short block = from the heads down
Long block = from the heads up
If you ordered a short block you would most likely get the block, crank, pistons, oil pan, etc...
If you ordered a long block you would most likely get the block, pistons, crank, heads, valve covers, etc...
A shortblock is the block, pistons, connecting rods, and crankshaft only. No heads, intake manifold, lifters, etc. A longblock includes the heads but still no manifolds. A crate engine is a complete engine ready to run with everything installed.
· FFCobra Fanatic
Correction - Crate Engine is an almost complete engine, but still needs a few things added. (plugs, wires, intake, throttle body, carb, etc.)
Turnkey Engine = Everything installed, drop in and turn the key.
· Charter Member
Ok, what about big block and small block?
Is it just the displacement size that's the difference?
Would it sound funny if I called my 1.6L Honda Engine a small block? How about a mini block?
· Charter Member
Oh come on, don't get me started on this.
Honda's junk, Ford's good? That's funny.
How many recalls does a 1992 Mustang have?
Also, there are many 650+ HP 4 cyl Honda's out there running low 10's.
1992 Honda Civic Hatchback, Normally aspirated
12.09 secs @ 112.80 MPH
1992 Honda Civic Hatchback, Turbo, no nitrous
10.672 secs @ 136.36 MPH
[ October 23, 2002, 02:19 PM: Message edited by: Crave ]
· Senior Member
Crave,
Given the ratio of 5.0L to 1.6L I would call it the 32% Block :D :D
