My motor is missing the lift hooks. Where do they mount on the motor and where can i get a set.
They bolt to the left front and right reat of the engine using the ford exhaust manifold studs. Probably easy to come by at junk yards or donated from folks here perhaps. However, mrpink is right you can use other means. Bolt a chain into one of the open threaded holes on the block or heads, tow strap, etc.
-Matt
[ January 02, 2004, 02:29 AM: Message edited by: Got Venom? ]
Get one of the lift plates that mount to the intake manifold. You can get one that has angle control too. I removed one of my lift brackets the other day, and the 2nd one is coming off the next time I'm working on that side of the car.
