There's a 351 block that I'm interested in purchasing. The markings are as follows D1AE 6015 DA12. Can someone tell me how to identify that?
Very good block. Same one as I found. 1971 casting. All around beefier block than '74 and newer blocks. The main webs in particular are thicker. It is also the first year casting with the current 9.503" deck height (older 351W were 9.480"). I had the block sonic checked and there was more than enough material to safely take it .060" over on the bore.
Regards,
Can you explain, or refer me where I can get that kind of info. Thnx for you help =)
