I broke #5 rocker arm last winter on an accidental overwind and am just now getting around replacing them. I decided to replace all the rockers with the Comp Cams Hi-Energy Rocker, Ford SB 1.6 3/8". I think I've got the hydraulic lifters adjusted correctly. While I was at it I decided to check the compression to make sure I didn't have some major internal issue. 1=190, 2=190, 3=190, 4=160, 5=195, 6=165, 7=165, 8=160
I always heard that up to a 10% variance is OK. If that is true I have issues.
The engine is a 347 with improved 351 heads Comp Cam, Headers and mild stuff. Less than 10,000 fairly easy miles. I'd appreciate comments if I should have concern with just putting everything back together and go cruising.
