Now you need to calculate your effective cylinder pressure, and your dynamic compression. This is very important. Cylinder pressure is what makes power. Not enough, and it will be a dog. Too much, and it will beat itself to death. Been there, done that!
Around 8 for dynamic compression works out really well. You'll need to be carefull on your tune, and keep total timing rather conservative. People seem to want to run a lot of total timing. But dyno testing on my engine shows it makes more power with a little more timing down low, and a little less up high. I only run 33* total on race fuel, and 31* total on pump gas. I also run a light spring so the timing comes in quick.
to calculate your numbers, I'v found this one to be about the easiest to use: United Engine & Machine Co. Incorporated
BUT.... this one does not take in to account altitude. So if you live above about 1,200-1,500' ASL, use one that compensates for altitude.
Wallace Racing: Dynamic Compression Ratio Calculator
