OK, the FFR manual says to run the battery cable down the left side, under the driver. Then I assume you wire it to a solenoid and the ign switch..etc, then over to the starter (hope I'm close). The question: I'm using Summit Racing's "mini" starter, with an internal solenoid. Can't I run the battery cable down the pass. side, since the starter is on that side, and tie the battery and ign-sw using a junction block. Seems easier. (shows how much I know!) If you can "decode" this and reply, I would appreciate it...thanks..
