1 - 2 of 2 Posts
Head lights wired using a relay (actually two relays) When I turn on the head lights I get high beams but when I hit the dimmer switch the lights go out. Is there a simple answer? It's not the dimmer switch I by passed it.
Thanks Stan
Without knowing exactly how it is wired, any answer is a guess. What wire harness? Are the relays one per side or one for low beam and one for high beam? Do high and low use the same exact power source?
1 - 2 of 2 Posts
