1 - 3 of 3 Posts
AAW wiring harness.
Did anybody else know that the headlight switch can't just be mounted but has to be specifically grounded? Arghh, Could not figure out the electrical circuit for the courtesy lights using the schematic provided. It kept coming back to not a complete circuit. I finally checked by grounding the outside of the switch casing. That was it!
To make your courtesy lights work as per the provided schematic you must ground the headlight switch case. Vent done. :D
Mike M.
[ June 17, 2007, 12:44 PM: Message edited by: Huckleberry5 ]
section 8
Great info glad your ok now . This will be a big help to others . Bob
1 - 3 of 3 Posts
