I don't visit the forum much anymore, but I thought I would post on my recent EPS install. So my car is a MK3 completed in early 2007 and registered as a 2005. Originally built in Granite Bay ,CA. by me garage paint and all. It's a basic aluminum headed 5.0 roller cammed 4 barrel double pumper 4 into 1 headers, solid live axel 15 inch PSE wheels a/c heat and heated seats and almost forgot an APE hard top with flip up sliding windows. So now it also has EPS or Electric Power Steering I used a Saturn Vue unit that I purchased off ebay 4 yrs ago, yep 4 yrs ago...
First I'll give an overview of finished product. WOW ! I mean WOW!!!!!!!
Single greatest improvement bar none of any mod or improvement I've made that includes all my various brake upgrades....
The project took about 20 hrs including paint and 2 two trips to Tractor Supply. I have a welder and other basic stuff but no lathe or even a big drill press anymore. I made this to be fully removeable / installable without loosening the steering rack or disturbing any other component. If it was during the build process and I could sit in the engine bay and not worry about scratching or messing up anything I would take 3-4 hrs especially if I could weld it in place. If you were to make the steering shaft rigid non collapsible ala ffr mk3 probably about 2-3 hrs.
Biggest challenges 1. getting vertical 3/4" support bar in correct plane as to not torque motor 2. Keeping everything aligned and steering wheel indexed 3. making connection to starter ,no room left on the lug.
I didn't make this a how to, too many variables but here are some pics of the completed project.
I'll answer any questions I can.....
Vertical 3/4" tube and mount bracket are separate pieces 1/4-20 bolts welded in place and also act as ground points
sleeve over cut ffr steering shaft and pinned with two 1/4- 20 bolts
Franken Bracket----FFR spline cobbled to Saturn Vue motor output
