Hey Paul!!
I think we batted this idea around about a year ago.
I was thinking that with a hard/soft top, that it wouldn't take much to heat the cockpit to a tollerable level.
Go to www.aircraftspruce.com
Part # K12-2500 Infra-red Cabin Heater.
I would make it removeable and just use it as needed.
Is this doable??
Thanks!!
Rob
I'm sure you could do it. They draw a lot of amps. I'd run a dedicated wire from the battery side of the starter relay. Also, if you have the stock alternator you will experience a serious lack of charging at stop lights.
Discussion Starter #3
The two types offered draw either 25 or 35 amps.
That doesn't seem excessive, considering I'm not running any other electrical accessories(other than a stereo). What kind of output does a new, stock type alternator put out ?
Thanks!!
Rob
