· Mustang Convert
I don't know what the original looks like but can speak to how this one fits. As far as fitting the oval opening perimeter wise it is a perfect fit. The channel in the grommet is designed for a slightly thicker firewall though. With just the aluminum from FFR the grommet floats a little due to the thinner aluminum compared to the rubber channel. I plan to fix this when I apply the Fatmat to the firewall by removing the grommet and matching the Fatmat up to the hole in the aluminum. The additional thickness of the Fatmat should make it a tight fit.
Btw, the hole in the grommet doesn't have any sort of expandable sock to adjust to the size of the harness running through it.
Kevin
Sent from my iPhone using AutoGuide.com Free App
