1 - 3 of 3 Posts
My donor EFI engine harness is clean, good flexible wires, new high temp loom, but the harness connectors (salt and pepper shakers) seem to be intermittent / questionable.
I have read some have hard wired them, some squeeze the female connectors to tighten the connection.
What seems to be working the best?
Thanks in advance, Jim
Ford has or used to have a salt and pepper extension harness that was installed free of charge as a recall item. I may pay to see if they still stock this item. You could use the extension harness plugs for parts to repair your defective connectors. The connectors are easy to take apart, and you will have new OEM connectors.
1 - 3 of 3 Posts
