1 - 3 of 3 Posts
Any idea what code 44 and 94 are related to. I have the code description but not sure if they are a problem?
Code 44 - Thermactor air system fault
Code 94 - Air diverter solenoid circuit fault
These both have to do with the solenoids that control the air pump circuit. So if you removed the air pump they would be expected. They won't affect performance but if you want to get rid of the codes you can use resistors to make the computer think they solenoids are there. Do a search on "TAD TAB resistor" and you should find posts on what resistors to use.
Cheers, Rod
1 - 3 of 3 Posts
