If a EEC computer for a auto transmission (A9P) is used in a car that has a manual transmission will it cause problems? :confused: Can a manual computer be used in a car with an auto tranny? :confused:
Nobody Special
Not a problem. computer pin 30 is the circuit you need to connect correctly.
Automatic computers - pin30 is connected to ground
Manual computers - pin30 is spliced into the SIG-RTN circuit on pin46
It will run even if you hook it up wrong. The only effect this circuit really has is to stop a KOER test.
Thanks Ryan, for the info and could you tell me if the resistor that is used to fool the computer for the EVR is the same for TAB/TAD and CANP the same? Should the resistor be 70 OHMS?
