Coyote in the House (continued)
Last thing for now with the engine, I went through the Factory Five Coyote instructions and tried to verify every connection, hose, etc. Posted a forum thread, and received some good feedback. All is accounted for except two extra vacuum hoses by the throttle body. Thanks to another forum member, determined the one on the PS is for the power brakes booster, so I will remove and use that vacuum source for the fuel regulator. The one on the other side is for the already mentioned CMCV system. This will require a connection to the Spectre intake tube.
One aside comment. Some chatter on the forums about the necessity to use the remote oil filter setup. Many have avoided doing this by using a lower profile oil filter in the stock engine location, which is what I was planning. Some though didn’t like the reduced filter size/capacity as a result. I went ahead and picked up one of the recommended lower profile filters, an M1-113. Once home, I compared it to the OEM C336B filter I removed from the engine as received from the factory. Guess what? Same size. Looks like Ford had to reduce the size of the filter due to the oil cooler noted earlier? Also suggests this smaller filter should be fine. No remote oil filter for my build.
To wrap up, while I haven’t done much with it yet, here are some observations and pictures of the new control pack. First some obvious differences. The old control pack had the O2 connections on the supplied harness. The new engine has them integrated into the engine harness. (Even though the O2 sensors they provided don’t fit into the engine connectors. Open topic with Ford Racing technical support. Looks like they provided the rear sensors instead of the front ones. Same thing I guess but obviously different connectors.) Old harness has an electronic power steering connection, the new one doesn’t. No problem for our builds. New harness has A/C connections (not needed for my build) and clutch bottom and clutch top switches. More about that later. The new control pack has a brand new PCM and power distribution box. Both completely different than the old ones. The new control pack has a fault indicator light for the dash, I assume similar to a check engine light. Tells you a fault has occurred and you need to read the codes. Ford Racing tech told me the new control pack does NOT need the speed dial like the previous version. We’ll see I guess. Finally, and this one I’m a little upset/surprised about, the new control pack doesn’t have a tach connection. (!!) When I asked Ford Racing technical about this, he listed off all the stuff the new system has that weren’t in the old one. OK, but how you could miss this? He mentioned using an Autometer tach adapter. Don’t know about that. Looking at the Speedhut gauge instructions, looks like not too big a deal to tap into one of the wires on the coil-on-plug connectors and calibrate to that. To be continued.
OK, here are some pics: This is the new PCM. According to Ford, this is a “next generation” from the previous one, and a completely new operating system and program. Bet the tuner crowd likes that. It’s much smaller and lighter than the previous version, but looks like it will need to be mounted in a similar location based on the lengths of the supplied harness. A little interesting for me, I kind of recognize that supplier name on the PCM. I also recognize the codes and know this was manufactured in a plant in Seguin, Texas where I spent a lot of time. Yep, the company I retired from.
This is the new power distribution box. Looks a lot more like something you’d see under the hood of a DD. In fact, that’s probably what it is. No wires to connect on the inside of this one like the former version.
These are the already mentioned clutch “bottom” and clutch “top” switches provided. They have dedicated legs on the harness. According to Ford Racing tech, they are mandatory. The bottom switch is required as a starter interlock. The top switch apparently triggers some reaction by the PCM to the engine when the clutch is started down. I’m not going to question them. I will install but thinking not to use these exact switches. Measuring them, they’re just 2-wire NO and NC contact switches. I’m thinking I can use the typical switches we use on our builds, like the one on the right. The top switch can be mounted in the Wilwood box just like a brake switch, and in fact I already made and installed a bracket like that on the clutch side anyway. Then just need to figure out how to have a similar switch at the bottom of the clutch stroke. Stay tuned for that as well.
This is the provided drive-by-wire (DBW) accelerator pedal. Same one as before. Still thinking about how I’m going to do this one. Not a fan of the way FF suggests to modify it. Lots of ideas on the forums.
Quite a few changes in the way power is brought into the new harness. These are the power cables provided, including an inline 250 amp fuse. The main power input to the harness is the 2-pin large Weatherpack style connector on the right side. This goes into a connector next to the power distribution box.
Last but not least, no apparent change to the MAF sensor. The OEM one removes from the provided stock intake components and bolts into the recommended Spectre intake tube.
That’s way more than enough for now. My plan is to wrap up a few more details on the engine, and then drop into the chassis. Without the transmission for now, so should be easy enough. Obviously I will need to support it accordingly. I want to mock up and confirm all the engine compartment and footbox sheet metal.
