Status
Not open for further replies.
1 - 2 of 2 Posts
· Administrator
On our Coupes we are installing Engine Factory 351W's with Edelbrock Performer intakes and 750 carbs. What bracket do we buy to use the FFR supplied cable to the carb? I called Edelbrock, but they didn't know how to hook up the carb because we are using EFI cables; right?
Help!!! We're soooooo close to a go-cart it's almost scary!
[ August 28, 2002, 03:08 PM: Message edited by: Bill ]
· FFCobra Craftsman
Similar set-up in my roadster bill..
I went with the locar carb cable bracket, cable and the like from summit. Cost about $50 for everything. I have the SS unit with little issue but I have read folks feel the SS braid gives too muchand are going with the black cables?
The Locar cable has a fitting that you put on the end of the bare wire after you cut to length (I got the 3' unit) I would thing if you want your cable you could cut off the end that went to the EFI and then add the Locar end to attach to the Eddi Carb?
Good luck.. Soooo Close Yet Sooooo far away!
1 - 2 of 2 Posts
Status
