Can the "E" cam be used w/ the 1.7 rockers that came in my 1993 Mustang Cobra engine. Anybody else using this set up? Heads are the F3ZZ GT40 heads. Thanks i really appreciate everyone here, any guess timates of RWHP? Stock it's putting out 245RWHP and 285RWTQ
I have the E-303 cam and Crane's 1.7s in my car. Crane made the 1.7s for the 1993 Cobra engine. I have ported and polished "Powerheads", which are stock E7TE heads, but worked over with bigger valves, etc. I used the stock pistons. Clearance is not an issue. Not sure about the GT40 heads, though.
I guess I didn't really answer your question, did I? Post this in the "Ask Levy Racing" forum. You'll get an answer for sure.
I am using Scorpion 1.72 roller rockers and the E cam with my 347 with Twisted Wedge heads. I have not installed the engine in the car. I had to install longer push rods to make the rockers work. I have plenty of clearance with the pistons. No estimate on the rwhp.
just another builder
yes...you'll have .529 lift where .530 is the max with the stock pistons...of course it wouldn't hurt to clay it...should make 330-340 fwhp...it's kinda my set up but when i went forged pistons i fly cut them in case i wanted to upgrade later...i have the y Al heads...you may need to up the injectors too
my best guess with the "E" cam is .512 lift if the rockers are 1.7.1 or .516 if the rockers are 1.72.1..........
We have the GT40P heads, E cam and Ford 1.7 rockers with a carb.
No problems, its 280 RWHP and 300 RWTQ.
Rick
not correct...no offense...(.498/1.6)*1.7 = .529
No offence taken at all!!! i've been insulted before! i really appreciate you catching thatm good call!!! whay would u possibly be concerned with helping someone possibly make a big error. Thank you
LOL...it supposed to be
"I've been insulted before...but by better people" :D ...i'm no expert by any means, i learned the most by screwing up or by askin'...i've asked this very same question in my past ;)
the helpin part ...well that's what we do here, it's kinda refreshing
