does anyone have a detailed picture on exactly how the emergency brake handle is supposed to pull the e-brake cables?
I am having a problem with mine. When i pull the handle, the pully that is supposed to pull the two cables doesnt pull with the handle.
I think the gears on the handle are not engaging properly.
any help wold be greatly appreciated.
Larry Bolanowski
Larry, I had this problem also. I don't have any pics, but the problem is that the e-brake cables supplied by FFR are a bit too short. What I did is take the metal connector with the 3 holes and cut, bend and reweld so that it resembled more of a V than the original straight shape. This extra slack was just enough to allow the ratchet and pawl to engage.
I guees ill give it another try.
FFR didnt supply me any cables.
I just dont understand how the pully engages on the teeth. When all else fails, weld weld weld
i forgot to mention.
the ebrake cables i am using are from the donor. they do appear to be at the correct length.
Its just the pulley on the handle that the cable wraps around wont engage.
Larry, I had the same problem and found if I pulled the E-brake cables far enough (about another 1/2') to engage the pawls on the brake itself it worked fine after that.
thanks guys,
ill try it tonite!
