1 - 3 of 3 Posts
i have 90 donor with drum brakes,here are my problems: with cables routed under 4 inch crossmember, they look like transmission mount will interfere. Also, cable equalizer binds with e brake mount and the e brake handle is so close to aluminum, unable to get hand around it. Also, is there any way to adjust slack out of e brake handle? It seems like u need to pull it all the way up to engage. thanks
Make sure your rear brake shoes are adjusted properly ie. as close to the drum as possible. If you can't find any other solution, you can shorten the cables. Go to a place that handles winches or wire rope; they should be able to swage new ends for you. Measure twice, cut once!
I put my handle on top of the trans tunnel, so I can't answer your other questions.
Dennis B.
1 - 3 of 3 Posts
