During the 500 mile return trip a gremlin showed up. I was driving along fine until the first stop. After the stop, as I was accelerating out of the gas station the car momentarily hesitated but it grabbed and we took off. After the second stop the same thing happened only worse but it self corrected and I was on my way again. After the third stop I could barely get going. Got on the interstate and it was so bad that all I could do was idle. Whenever I tried to accelerate, the car would just bog. I drove down the shoulder for about three miles just idling along and trying to get it to catch and run right. Finally, it caught and I was on my way. But during cruising at about 65 MPH it stumbled twice more for about 2 seconds, caught again, and got me the rest of the way home. Once running I was fine but I knew that if I shut down and started back up the routine would start over again. What the heck is this? It isn't electrical as I never lost my lights. My guess is it's something in the EEC or fuel delivery.
The best way to describe it is if you've ever forgotten to put the spout back in after setting timing. Car runs fine until the RPMs climb then it just won't go. Another description is vapor lock. It just feels like it's starved for fuel. I can get it to rev fine in neutral but it won't accelerate under load.
I went out this morning and checked all connectors and grounds. Everything is where it's supposed to be and the car will start and idle although a bit roughly and it smells rich. Fuel pressure is where it should be. Where do I start the diagnostics or should I just throw the voodoo away and go to carb?
By the way, many thanks to Rick Burnstin (Creamsicle) and Paul Brannan for sticking with me in with their tow rigs and making sure Nancy and I made it home. They weren't about to leave me stranded on the interstate.
