Dave, I use the 1/4" socket and extension also, but I put some duct tape over the socket-extension joint. Also if you've got help, it's a good time to bleed your oil pressure gauge line to get the air bubbles out. When re-installing the oil pump, if the dist doesn't sit down all the way, don't panic, just re-incert the 1/4" drive and turn the pump a little until the dist sits down. Take your time when incerting or removing the 1'4" drive stuff, there's always a chance of separating the socket. That clunk, when the socket hits the bottom of the oil pan is no fun. Good luck, Bob
