I used a 13mm flare nut wrench. Put it on, gave it a twist and voila.
You could also try using a nylon wire tie (zip tie). Cinch it down but leave a little room to start pushing the retainer through. Then, as you push it through the wire tie should slide off.
Good luck,
Walter.
