1 - 2 of 2 Posts
I was trimming the notches out in my lower control arms when I noticed that the factory rubber bushings are pressed in differently on each arm. The steel sleeve is pressed in fully on the front of one arm, with the rear bushing on the same side, about an eighth of an inch from being fully seated. On the other arm its just the opposite, the front bushing is an eighth inch from being fully seated, with the rear bushing seated tight against the arm. Are the bushings supposed to be pressed in tight on both sides of the arm? It would appear that what I have would affect the caster.Any Suggestion?
Gary
1 - 2 of 2 Posts
