Would like to separate spindle/rotor from LCA. Pulled cotter pin. Used impact wrench, but entire ball joint is turning? Is there a way to prevent rotation of the whole ball joint? Also is there a "miracle tool" to remove LCA bushings from
LCA's? Same "miracle tool" to install new poly bushings? Very tight!!
Thanks. Don
Thanks. Don
