1 - 2 of 2 Posts
I'm using the stock gauges and pod set up from my 91 donar.I cannot remember what wires go to the threaded posts on the back of the VOLT METER. Also why does FFR give you a amp gauge,why do you need both? I was hesitant to use the donar gauges but after seeing them i think they look pretty good in the dash. THANKS
On the '89 harness, R/Y wire provides power to all the instruments. Black is ground. Don't know if the '91 colors would be the same.
1 - 2 of 2 Posts
