I am wondering if the FMS/McLeod bellhousing comes with a clutch arm boot or do I just reuse the one from the t-5? I plan on getting a Tremec from Forte. Just want to know what to keep from the t-5. Thanks.
You mean the cover for the hole in the side where the clutch lever arm sticks out? No, mine didn't have one. I was planning on leaving it open and just drilling a small hole at the bottom for water drainage.
And the cover from the Ford bell will not fit.
Frank.
Anyone have a picture of this boot? I have a stock t-5 with the stock bell housing, and I do not have a boot.
Tom
Hi Tom,
I have the stock fork cover for a T-5 bellhousing. McLeod doesn't offer a fork cover or a boot & neither does Lakewood.
Mike Forte
Forte's Parts Connection
376 R Cambridge Street
Burlington, MA 01803
ph: (781) 273-9900
fax: (781) 273-9955
I drilled and tapped the Mcleod bell housing and used the original cover. Doesn't cover the hole completely, but close. I had to dent the cover a bit as well if I remember correct.
