1 - 2 of 2 Posts
I am using a 2001 Mustang Cobra donor on my Mk IV. I have power to the fuel pump relay and to the fuel pump but no function from the fuel pump. Everything worked perfectly when I disassembled the donor in January so replacing the fuel pump is not my first instinct. I am not using the evap system. Does that effect the performance of the fuel pump?
If you have power to the relay and power to the pump, and the pump isn't working, you have a grounding problem or bad pump. Test the pump by itself on a battery to be sure. To answer your question, NO.
1 - 2 of 2 Posts
