1 - 2 of 2 Posts
Well I am cobbling together a newer 302 with older parts.
To be specific I am piecing together to place an order for a 94-96 302 long block with E7 heads and the explorer roller cam. How ever I will be using a old '82 Duraspark II dist.
I know I need to run a steel distributor gear to be compatible with the roller cam.
Now I did some looking and on summit they list way to many different size distributor shafts. I looked on jegs and they showed a 0.467", 0.468", and 0.531". Now I haven't pulled the dist from the old engine that I will be using parts from just yet, as I want to drive the vehicle to where I will be pulling the engine before the swap.
Does anyone here know what size shaft it should be?
What about fitment? Anyone knows which dist gear will fit? I saw some claim that the distributor gear is a press fit with the roll pin not holding anything really. But I know the roll pin is supposed to be a shear pin and I thought it was just a slip fit. I wouldn't know never pulled a gear off before.
Just looking for some help on picking the right dist gear that will fit.
Hi Rusty,
I'm no expert but I've played around with different distributor gear options on my (351W based) engine before. I think reference to a .531" shaft diameter is 351W, not 302. They are both small block Ford's but the 351W uses a larger oil pump driveshaft and so the distributor shaft is larger to accomodate it. The numbers under .500" are meant for a 302 (or 5.0l) engine. Every manufacturer seems to advertise a slightly different distributor shaft measurement. Sometimes because they are actually designed as a slip-fit distributor gear (Mallory often used this method) while others remain interference-fit like the OEM Ford. Speaking of OEM, that's what I would recommend. The best method to be sure you have components that work together is to stick to pieces designed to work together. I don't know enough about the Duraspark II distributor to say if it was ever used with a roller cam or not but I know Ford never altered the diameter of its 302 (or 5.0l )distributor shaft, only aftermarket sources changed the distributor shaft diameter. Use your Ford distributor, your Ford roller cam and a Ford steel distributor gear (ask for one to fit a 95 Mustang, ignore aftermarket brands) and you are golden.
Sean
1 - 2 of 2 Posts
