I have now gone through two distributor drive gears on my 351W, Edelbrock Performer carb, cam and intake, Accel point distributor and MSD ignition box. The most embarrasing part is both time the gears gave out in the same place. In front of an appartment building with Hispanic residents. They were really nice and offered me water and tools. Everyone is your friend when you drive FFR. Eight different cars stopped to offer help.
I believe the first gear was my fault because I did not torque the carb studs enough for fear of damaging the aluminum intake. My nice Cobra air cleaner is rather heavy and I believe it loosened the carb as I bumped down the road. A large backfire broke two teeth off of a perfectly good gear.
The second dead gear is stranger than the first. It is a Motor Mite 351W gear that is the only one I could find in town. After two hours of running time, the teeth wore down paper thin with edges that were razor sharp. This time there was no backfire. Instead, the advance changed over a two block run until it was too retarded to run. Turning the distributor for more advance got it started again, but after another blocks the teeth wore through and again no dice on getting it running. One flat bed tow truck and it is in my garage again. This was on the way home from the front end alignment and carb adjustment.
I am using a high-volume oil pump, but I don't think that would destroy a distributor gear in two hours. I wonder if it was just a really crappy gear and if I should try the MSD I ordered from Summit. All three gears are iron, but I don't believe this mild cam should require bronze or steel. What is the consensus on this? Anybody have any ideas?
It was fun for the four blocks I got drive it and as I mentioned, everyone is my friend when I am standing stranded next to my FFR. people asked if it is a Roadster, and I answered, "No, it is a sitting beside the roadster."
[ September 12, 2002, 12:32 PM: Message edited by: Uraeus ]
