1 - 3 of 3 Posts
Hi Everyone!
Things seem to be working correctly except dir. indicator. When directionals are on the indicator works fine. When they are off the green light stays on. The third terminal to light then the second lead I fed to ground. Any thoughts on what I screwed up??
Bill, I had the exact same problem and the following response from Jeff Benaway took care of it.
This is a easy fix, the green light has two wires one goes to the bottom prong on the flasher. The harness has the two oem plugs that go on each side of the of the flasher. Now you take the second wire from the green light and instead of grounding it like the book tells you, you splice it to one side of the oem plugs. First you have to determine which side will make it flash, I did this by touching the bare wire near the prong. Also you must have your lights hooked up ,because there must be a load before the flasher will work.
Good Luck; Tom
Thanks Tom!
If I understand you, The Build Manual is "WRONG"??
I will try it tonight!
1 - 3 of 3 Posts
