I'm thinking about changing from dino oil to synthetic motor oil. My motor has 130,000 miles on it and runs great, I need to make is last. Any and all feed back welcome
Thanks Fish
Tropically Twisted
one word.
Amsoil. Prices are comparable with any other synthetic out there, and the oil is top notch. I won't use anything else.
be prepared for leaks when putting synthetic in a high mileage engine that's always run on dino oil. The synthetic will dissolve all the years of built up waxes & sludge at the seals, and you mysteriously end up w/ new oil leaks!
I'll second the Amsoil thing. I have used it for several years now both in my truck and in my motorcycle. I wouldn't use anything else either
Former Roadster Owner
I'd stick with conventional oil. I'm guessing you have a stock 5.0 engine that you've coverted to a carb'd set up. 130K on a roller 302 is barely broken-in. The synthetic oil will likely cause a leak. Conventional oil has come a long way in the last 10-15 years, its better than many people realize.
There is nothing wrong with going to a syntheic at 130K miles except the fact that it may find an escape route onto your garage floor.
Stay conventional. Our company runs trucks. Last year we bought a sprinter van that calls for synthetic oil ($50 an oil change) After sending the oil out to be tested at 10,000 miles the aluminum and metals content showed the oil needed changing. After runing the vehicle for 30,000 miles and testing the oil after each 10,000 miles we switched to our conventional oil ($10 an oil change). Same readings after 10,000 miles. Why pay $40 more an oil change! Oh the van has 430,000 miles on it and going strong.
