I haven't found a torque spec for the rear bolts which have a lock washer. Also, How tight do you make the front bolts that go through the large rubber bushings? Manual just says "tighten."
Runs with scissors!
You should be able to look up the bolt sizes in the generic torque specs chart in the back of the manual. I don't recall what I set mine to.
We are at the same point in our build.
Appendix F (Page 240) of the MKIII assembly manual has a chart with the torque specs for the IRS fasteners.
Appendix G (Page 257) has charts with general torque specs.
