Wanted to use my 14" air cleaner so...
Prototype
and Finished
Air cleaner stayed cool after a drive. Not the prettiest but functional.
The Traveler
Nicely done!!:)
FFCobra Captain
You notice any difference in throttle response? Colder air should give you a little bit of a benefit. It's more noticeable on a boosted car though.
Nice work.
Sanford that is excellent. Makes a pan workable. I have always just ignored them. I like the look but the fact that it is in the way all the time and the carb has to come off to move it = not for me.
FFCobra Captain
The pan I got from MasterTouch ( MASTERTOUCH327.COM ) is easily removable to service the carb.
There's a bottom plate that stays in place and the side 'ring' mounts to it with 4 machine screws, so you can easily lift it out of the way if you need to get to the carb.
I haven't looked into sealing it to the hood...gonna have to check into that.
I wonder if one of the cowl induction seals from a Camaro would fit the turkey pan and be tall enough? Here's a video of a guy installing one and it looks like the camaro base has a similar lip. Would have to cut and glue the rubber back together though.
https://www.youtube.com/watch?v=8eYs3Jouz-4
The wing-nut on the air-cleaner holds it all in place. Removes as one unit. The pan is riveted to the lower air-cleaner housing. I'm using Poly motor mounts and haven't had any issues at all. I have since removed the filter top for a conventional Moroso curved top and a 1/2" taller filter with more surface area. Its hard to tell any power increase as it is many many many times faster than my daily driver.
