Check out the pictures at the end of this thread and you can see the difference in the two headers. The top is a 302 and the bottom is a 351W. The #8 primary has a shorter tube from the head to the first radius on the 351W pipes going toward the footbox. Hope this helps.
Check the box they came in... It will probably be stamped 302 or 351... Not that this guarantees what is inside, but hopefully they are at least checking it when they do the final packaging.
Thanks for the info.. The box is labeled 570R10. The other thread mentions that the 570R10 are the 351 headers. I hope this is right...
Be careful, FFR apparently had a shipping mixup problem sometime in the past several months on the 4 into 4 headers. Quite a number of people ended up with one or both headers for the wrong engine (305 vs 351). I know 1HOTSC got them wrong twice.
