Status
Not open for further replies.
Does anyone have experice with these plugs in Blown 5.0 applications? There was an article in this month's 5.0 mustang mag. which posted 15 hp on the chasis dyno with the change in a blown 4.6. They are rather pricy about $12 each but with the plugs being as hard to change esp #7 it may be worth it if they work well and last longer.
I've always been a copper plug guy but I'm willing to change for more HP.
Running colder plugs is always a good idea in blown applications to reduce KR. Best bet is to tap that computer and see how much KR you have. On my Buick I run about 13PSI of boost with no KR.
I was going to ask what "KR" meant, but I'm guessing it means "knock retard"? The EEC-IV harness doesn't have provision for a knock sensor. At least 87-93. I don't know about the later years.
I don't have any experience with them but I read the same article and have read others in both mags with similar results. Based on the dyno tests, these plugs look like an excellent product, but for $12 each?....don't think so.
I'd stick with Autolites and maybe index them if it makes you feel better.
Sounds like good advice I'll stick with the Autolites. It's an easy change now as my heads are sitting on my work bench.
As soon as the sharp edge erodes a bit on any plug, more voltage must build up before the plug fires which tends to diminish fat amperage spark heat. Plug crispness can be extended by occasionally filing the electrodes on any plug to a sharp edge again. I agree that a bit of snakeoil is present in hyped aircleaner and sparkplug advertising.
Status
