The instructions don't specify on how to mount the defroster duck that goes to the windscreen. Does the plastic duct fit on top of the body - hence small screws to screw it down into the body or under the body so the duck does not show and you only see the hole you made in the body? It would seem that you would get a better finished product by having the plastic duct on top of the body. Also, how does this affect the strip on the body. Where is the best place to make the hole for the defroster duct?
Russ
That plenum is awesome. NCPainter put mine in as the body was being mounted and it works perfectly. You can then take the second hose across the dash and pipe some warm air into the driver's footwell.
