you are correct. Here is a look at business side of the under dash panel.Great videos! I really like your wiring. I assume the panel with the relays is mounted on a hinge under the dash and you had it where it is just for wiring purposes?
FUN TIMESi will mot be posting every little thing, but will try to hit the unique and milestones. That said, I will start with some mundane.
Delivery Day, Sept 30, 2017
Pushing it down the street to the house
Body Moved to Buck
Ready to start Assembly
I'm looking forward to getting started Dean
My shaft is short as well. They told me it was too short to balance...did yours get re-balanced after it was modified?i purchased a new 2004 furl tank and need to identify the parts indicated on the included picture. Does anyone have the part numbers or Ford's name for these parts?
thanks Dean
I ask that it be balanced. They did not mention not being able to do so.My shaft is short as well. They told me it was too short to balance...did yours get re-balanced after it was modified?
I have reinstalled the oil bypass solenoid. I am having an idle issue where, after 5-10 seconds, the idle RPM would go up about 200RPM above the idle set point. The tuner, using an SCT X2, tuner was not able to resolve the issue. I removed the resistor and reinstalled the oil bypass solenoid, which improved the situation. Now the idle goes up about 50RPM. Note that this occurs with a deffinate change in tone.Gen 3 Coyote Oil Pressure Sender
The factory sensor is required. The wiring harness sender is also required to make the oil pressure gauge show the oil pressure. I choose to eliminate the oil bypass solenoid also. I did this by replacing the Gen 3 oil filter adapter with one for a Gen 2 from a 2017 mustang. I put around 100 miles on mine before making the factory oil pressure sensor work. There were not any DTC's associated to the oil bypass solenoid when the oil bypass solenoid wasn't connected. However, Ford Racing instructed me to place a 100 ohm resister in the wiring in place of the solenoid.
Note that without the factory oil pressure sender the ECU limits the engine to about 3500 rpm.![]()
These pics show the difference in the adapters and the final installation
View attachment 358336 View attachment 358337 View attachment 358338 View attachment 358339
Note that the block has 3 openings, The 2017 adapter covers all 3. Two of the openings are the filter supply and return, I assume the third is a return to the pan for the oil bypass solenoid. The extra passage shown on the 2018 adapter is the oil supply to the oil bypass solenoid. There are not any openings in the block in that location.
