David, do yourself a favor and build your own mounts. The mod motor mounts end up putting the motor too low in the chassis, even the low profile pans hang below the frame rails.
<---- Also waiting to see if PS will be used...I'm dying to see this ! I love this motor--do I hear 6 speed trans???Is the computer set up for 6 speed trans or does that not matter??
The pulley / damper ...........The mustang has electric power steering so if you use air cond and alt & .........................????????????????????????????????????
OK... ..I'll just sit back and listen,this will be interesting for sure
I wont know how much room I have till I get the motor in the car. I need to investigate small AC compressor sizes as well. Stay tuned...Dave,
Did you ever get a power steering pump to try to mock up?
So does that mean you are going to in stall A/C in your build?I wont know how much room I have till I get the motor in the car. I need to investigate small AC compressor sizes as well. Stay tuned...
David
I would really like to if I can get it to fit. The goal is power brakes, AC, and Powersteering.So does that mean you are going to in stall A/C in your build?
They just got another Coyote 5.0 to start mock up. It looks like it will be a while since they have to pull the 3V motor out, and then start working on it.Also have you heard any news on when ff will be takeing orders for coyote mk4s Thanks
