1 - 10 of 10 Posts
The body is on and w/ the padding on the dash there is no way the dash will go under the lip. The body is bolted down and i cannot move the lip forward. My only option is to knock in the 3/4" dash hoop forward about 1/2" to get it under. Anyone else run into this? The body is where it is supposed to be and wont move rearward any.
Dave
FFR Driver
Many have had to knock it forward, myself included. Its no big deal.
ok just making sure im not the first. I had to knock my vertical 3/4 tube on the pass side by the door latch mounting too to get it to mount.
quality control ???
Dave
Dave - it doesn't seem to be too much of a problem any more, but on the old forum, EVERYBODY had a 3' length of 2x4 and the requisite "BFH" to make such adjustments. :D :D :D
Sr FFR builder
AAAAARRRRGH! I am 90% positive that I will have to take the dash out and modify this friggin hoop. It appears that I am sharing in this misfortune. Damn
I just mounted my body for the first time and I must say I was amazed by how well everything fit. I need to make minor (3/8") mods to the header cutouts and take a touch off the rollbar cutouts but everything else fits fairly well.
Murph
Orbiting FFCobra.com
I've had my body on and off a few times, and it seems that the hoops is really close to the dash. I just mounted the dash, so I hope it fits when I put the body back on for the LAST time
I had to cut a 1/2" section out of each of the side rails holding the hoop nad knock the angled piece in a coresponding 1/2". Then I riveted and agled piece of aluminum to hold the two side rails together. This kept the dash flat once installed, instead of having a dip in the top center that would occur if you just pounded the center of the hoop in....Do a search on member #989 a few months back if you feel like reliving my troubles.
I ran into this problem myself. I cut the square tube brace that reinforces the dash hoop then used my small hydraulic jack and a 2x4 between the frame between the seats and the dash hoop to bend the dash hoop forward the required amount.
PSS
1 - 10 of 10 Posts
