I use a CRS1000 which is vacuum operated. Yours is electronic. The VSS pulses don't matter with either version but the sender does as you know. The T5 pulse rate is 8,000ppm. On my TKO they are 12,000ppm which won't work with a CRS1000 so I still use my 88-92 VSS for my signal. As long as the speedo wire comes directly from the VSS you can connect the two together there. Be sure you have a good ground on the VSS as well.
The surging is a dip switch setting and can be trial and error to find what suits your driving. I've had mine for 14yrs and love it.
