· Junior Charter Member
Question from a new builder. I purchased new FMS lower control arms for my build. Does anyone have a suggestion on the best way to cut the notch for the front coil-overs in these. I tried a roto-disc and the grove ends up being too much of a "V" (doesn't make a nice clean cut). I've also bought a bunch of blades for my old jig saw but they continually break. Does anyone have any suggestions they can pass along?
I wish I had a plasma cutter, but I don't..
Thanks!
Todd
· Senior Charter Member
I used a high speed die grinder with a high speed steel metal eating bit to rough it out and finished it smooth with a flapper wheel. I did not make a "V" but more of a "C" shaped notch in the control arm.
· Premium Member
For the first one I used a cutting wheel on a drill motor. Took two discs, 40 minutes, and made a heck of a mess. But it cut it exactly the way I wanted.
For the second one I use my new sawzall with a medium tooth blade for the two long cuts, and the cutting wheel for cross cut. Took maybe 10 minutes, and not nearly as much fuss/mess.
· Senior Member
I used a dremel cut off to rough it & then a 4" grinding wheel. Went back to the dremel to smooth it out afterwards.
· Super Moderator
Drill some holes across the base of the cut and then a hacksaw or sawzall on the sides. Break out the "tab" (wiggle with pliers or something) and clean it up with a file
I marked the area to be cut with soapstone and them took the arms to the local machine shop. They cut them with a plasma cutter for $10 in about 5 minutes. They also did the mod to the AC bracket at the same time.
[ December 27, 2002, 08:03 AM: Message edited by: teamfour ]
