I've ordered a carbon fiber dash panel.What is the best way to cut holes for gauges? I don't know how sensitive that material is to a hole saw. Let me know.
There have been a few posts on this but...
I bought an adjustable hole saw off ebay for like $20 and it worked fine. I had to resharpen the cutting knives after each hole, but still a clean cut. Undersize the hole a little and then use a dremel with a sanding disk to make it perfect.
I too used a hole saw actually three hole saws, for 5", 3 3/8", and 2 5/8", all undersized and finished to exact size with a drum sanding kit I bought at Harbor Freight for cheap. First I scribed the hole location with a pair of dividers on the front side of the dash, and sanded exactly to the line. Used a drill press and low speed. Came out perfect, but be careful, you only have one attempt on each hole. Measure three times and cut once. Rick
Shade Tree Mechanic
Saint Rick, If a saw is 5" how can it be "undersized"? Are you saying it was a 4 15/16" saw?
Hey Bill, THat was my post asking about the CF dashes. I love the look, but nobody ever said if I could use my aluminum dash as a template?
S/D, sure you can use the aluminum dash as a template, but be aware that the CF dash may not be the exact same dimensions as the aluminum one. Mine was about 3/4" shorter in height, FFR only knows why.
I would advise against gluing/sandwitching the two together. The two materials will have different temperature expansion rates and may cause them to delaminate. If you want to make it stronger (I did), add a layer of fiberglass before you cut the holes. If you want it even stronger (I did), bond a bar of aluminum to the bottom. This is also give you something to mount braces to.
You also asked about mounting a guage to the left of the steering wheel. That depends on the size of the guage, if it's a 5" unit like mine, no it won't fit, at least not well.
I would also second the notion of cutting the holes a bit small and use a sanding drum to finish off the bigger holes and a dremel tool for the smaller ones.
If you want to laminate the CF to an aluminum panel (I did)it's best to use 1/32 inch double coated foam tape 6-9 inches wide.
Clamp the two with pieces of 1 x 4 and let stand for a day or so and you will have an absolutely tight laminate.
Drill the panel from the aluminum side and wear a protective breathing mask,as the CF dust is NASTY stuff to inhale.
Paul M.
FFR, it's already pre-curved. I've one other but without the curves. I'd hate to try to do it.
