1 - 3 of 3 Posts
SOLD csr electric water pump SOLD
would be part number csr905 for sbf.
Generating an incredible 37 gpm of coolant circulation, CSR Performance billet aluminum electric water pumps give you the flow you need, without costing you horsepower. CNC-machined from T-6 aluminum, these lightweight pumps have a direct-drive 12 V motor, spinning a redesigned impeller on a stainless steel shaft. CSR pumps draw just 5.8 amps. Because they don't run off of your crank, they won't eat up race-winning horsepower. Other features include corrosion-resistant anodized finishes in several colors, superior RFI suppression, and a removable center section for cam adjustment or replacement.
includes backing plate, 5 x 1.75, 3 x 1.75, and 3 x 1.50 inlets.
$200 plus shipping.
Discussion Starter · #2 ·
just a note, because of my setup the inlet was moved to the top, so the ears come off and are reversed, they use 0 rings so the switch is easy, and the plug in one side was moved to the other but can be moved back as it is a pipe plug thread style deal. cheers.
1 - 3 of 3 Posts
