1 - 17 of 17 Posts
Hi all.
So I wanted my dash to be a bit different, mainly because it seems that most layouts have the gauges hidden behind the steering wheel somewhat.
So today in my little garage I have been playing with my F5R jigsaw, and this is what I came up with.
It started life as the competition dash but I moved it around because I was trying to keep the switches closer together.
So most these items should be obvious, but the white round circles are the switches, in order:
Hazard, Washer, Wiper, Horn, Ignition, Hi/Low beam, Headlights.
The indicator switch not shown on the right.
I would appreciate any feedback from current drivers, to see if you think this would work well out on the roads. I am pleased that I can actually see everything. The radio is just representative, not the actual model I will use (actually unchosen at this time).
Thanks everyone.
First of all, the wheel is on the wrong side of the car.
My personal bias is to hide the radio under the dash for three reasons. 1) It will look more "classic" without a radio, 2)you probably won't hear the radio anyway and won't use it much, and 3) if you get caught in the rain, the radio will be ruined. I got caught in some pretty bad unexpected downpours and one of them destroyed my GPS even though it was mounted under the dash.
Looks O.K.
Looks O.K. but I'm sure people will give personal preferences...myself included!I've only driven 1200 km and my dash is set up as shown in the build manual (MKIII non competition dash with donor gauges). With your dash, looking through the steering wheel, I would move the right turn indicator light to the right of the "Te" and place the high beam indicator between the "p" and "Te" (Oil pressure and temperature?).
Rocky
P.S. I didn't bother with a radio!
The steering wheel is on the wrong side...Edit*(Yes I am not the first to say it and guaranteed not to be the last :) )
I looked at the picture a couple of times, and although the radio in the dash wouldn't be my cup of tea it blends well under the three gauges. I would space out the switches above the radio to align under the gauges.
Make sure that when things get busy, your hands don't hit the switches. I have the standard gauge layout and like it. Can't see the speedometer to well but like having the tach right in front of me.
A suggestion, sit in the car with your eyes closed and pretend you are on a tight auto x course with things happening fast. Where do you want things to be? Do you hit anything as you turn and shift.
These cockpits are really very small.
Best of luck,
Arch
I'm not sure of your intended use for the car, but if it is for the track most people like the tach in front of them. It is your preference, though, and only you can decide how you mark your shift and braking points.
If that is taken from your eyelevel and you can truly see the temp gauge, I like it. I'm 5'7" with the bucket seats and can barely see my speedo over there when in go-kart mode. Personally, I'd put the clock where the temp is (can't imagine you'd want to really know the time once you're going), bump the fuel all the way over and put the pressure in there, keeping the temp on top of the wheel.
Also - switches were mentioned. If you are going for the horn fast, are you going to hit your key? Or your start/stop button? That looks kind of iffy to me.
Thx for feedback so far everyone.
In Australia our cops are real severe on speeding so thats why my speedo is right up front. (In a car like this, I know I am asking for trouble!!)
Maybe because it is a bit confusing, gauges left to right are:
Clock,Volts, Fuel, Tacho, Speed, Pressure, Temp.
The horn/key interaction does need some work .... good comment
Personally I would also swap the tach and speedo but I understand your concern. In either position I would rotate the tach so my shift point is at 12 oclock-no need to read numbers just shift when the needle is straight up. I like your oil pressure and water temp where they are as they are the two most important numbers for the engine's life.
FFCobra Captain
I'd swap the horn and headlight. Easier to hit the horn without having to reach over other switches.
A hidden radio would be nicer. I think it kills the vintage look of the dash having it right in plain sight.
Cool layout, but I'd agree relocate the stereo.
Question for you right-handers. Is the chassis/drive-train off-set to the left? Just wondering if there is a special kit or are you modding everything to the right-side (wow, that would be a LOT of work!) what donor do you use down-under?
keep us posted
Discussion Starter · #14 · (Edited)
Thx for the comments everyone.
I will look at relocating the radio - valid comments all. Also frees up more space for switches so might do a mod job there.
For some of the RHD drive cars over here, most guys have left the driveline where it was. Me however, I moved it so that it now sits central in the car, ie 1" to the left from factory. Given I am running an alloy block (lighter) I think I can get away with not offsetting it further to the left. Also, I did not want to get too far away from the diff pinion.
Also as second hand Mustangs are very thin on the ground over here (and very expensive if they are), we all tend to go the non-donor route.
At a minimum, swap the tach and speedo. Looking at the speedo is a low-stress continous habit thing while looking at the tach is more apt to be a high stress "giving it the beans" thing. I'd want the tach where it will be easier to glance at during the high stress situation. Plus it would put the gas gauge next to the speedo which is smart due to the whole continously-looking-at thing. Whenever you look at the speedo the gas gauge will be right there looking back at you, mocking you.
Personally I'm really liking the smaller "Sweep" tachs that you can get new from MoonEyes or vintage off of ebay.
If you haven't bought the stereo yet have you seen the Retrosound Apache? Not sure about the whole Aussie radio compatability, but I think I'd set up the Apache with both knobs on the driver's side with a small tray underneath for an I-Pod.
Do motors spin in the same direction down under, or do you have to flip the rear axle?
ditto switching the tach and speedo. you will learn how fast you are going in each gear by RPM.
be absolutely, positively sure you can hit your horn button in an instant.
hide radio if at all possible, i say it's inappropriate for a car like ours.
i don't understand where your ignition switch is... in any case, be sure your fingers won't hit it when turning the steering wheel.
you are doing the right thing by having the oil pressure and water temp right in front of you.
be careful of the bar that goes from the dash hoop to the main frame. not sure if it's there on your model, and not sure if it's switched because of your right hand drive.
Discussion Starter · #17 ·
No, but I think we have to reverse the polarity to get them to go the right way :001_tongue:
Be careful of the bar that goes from the dash hoop to the main frame. not sure if it's there on your model, and not sure if it's switched because of your right hand drive.
Actually my model is the same as the US model. The RHD conversion is all done by me, no Factory Five input at all. So yes, that bar is an issue. Actually if you look closer, you might see the gap between the tach and the fuel gauge - that is for that bar ....
The speedo/tach swap is interesting. I was sitting in the car yesterday and I swapped these gauges over. Not sure I prefer it. The trouble is if your hands are in the 10 and two position, your left hand obscures the speedo. And I cannot move it over anymore due to the dreaded bar.
And as much as I might pretend my car will live on the race track, reality is it will do 99% duty on the street, where speed will be the major issue!
Agree with radio comments - I have removed it. Also gunna lose the clock too. To many clocks in this world!
1 - 17 of 17 Posts
