The M-6670-A50 kit from Ford includes dual sump oil pan and pick-up tube (not required in the cobra), dip stick & tube, crank damper, timing pointer, water pump and timing cover. You'll also need: intake, throttle body, injectors, EGR spacer (if using GT-40 intake), distributor, plug wires, headers, heater tube (if you are installing a heater) and probably more stuff I can't remember.
[ August 24, 2002, 12:26 AM: Message edited by: PAB ]
